mart
- South Yorks
The nylock nut on my lever hoist has come loose during operation. It is not surprising as I think nylocks are intended for a single use, plus the threads appear to be shot now. It has been removed a few times.
The nut always screwed on anti-clockwise,( left-handed thread). It appears to be 8mm, but I suspect the thread is not standard, as a standard 8mm nut will not screw on. It is likely to be 8mm fine or even 8mm super fine, but until I try a new nut on I won’t know, and this can cause delays. Also, the nut could even be imperial.
Here are my questions so far that I need advising on:
1: Regarding left-handed threads, is it the nut that has the left-handed thread or the bolt/shaft that the nut is being screwed on to? Or, is it both? (I`m guessing it has to be both)?
2: Is AF the same thing as imperial?
3: Does anyone know a stockist in the Sheffield or S,Yorks area etc where I could take my lever hoist, to match the thread on the shaft with the correct nut?
4: Failing this, which online retailer should I try first? I want to crack on with the job that I am using the lever hoist for and don’t want to lose too much time.
When I tried the new 8mm nut from my stock, it was a standard right hand thread. Not sure what I was thinking. I was probably not thinking.
So, if I am lucky, I could simply buy a left-hand thread M8 nut and be ok without trying to source non metric ones?
but they were taking notice. My thoughts were that not all the visitor groups would be just potential customers.
, luckily we worked for a good boss who bought him a full set of metric tools
