123hotchef
- Kent
Good fun, isn't it?![]()
hell yeh! I might need some stubby drill bits I can see the deflection on these ones
Looks good, but why so many drill chucks?
As long as you start the hole with a centre drill then peck with jobber drills you wont notice the deflection
I have 6 for the same reason .save keep changing bits! I bid on a few and ended up winning them all!
Bought 3 mt1 for my old myford and chucked sleeves on them to make use of them.
https://m.ebay.co.uk/itm/Steel-MT2-...e&pageci=fb305dc6-e377-4063-8480-a9912fe74274do they do a sleeve to convert from MT1 to MT2? I have a MT1 here too
thanks ordered 1 I can have another chuck!
Most taps have a center point on the top.what is the best way to tap on the lathe? or should I do that by hand?
put a Center in the tailstock with a tap handle fitted and use it to keep it true to the chucked part while turning by hand. Use the same method in a pillar drill too.
I normally gently wind the ts out as the tap works in.
Nope.so you do not use the lathe motor at all
Nope.
Not saying you can't but easy enough by hand on the lathe.
Could also stick the tap in the tailstock Chuck and turn the lathe Chuck by hand to tap it in the workpiece
Beat you by a hair...Turn the chuck by hand?
Dave H. (the other one)
It's turning it off and reversing it that's the problem lol.that might work, I would be scared to turn the lathe on!
