Bullyterrier
So Mote It Be
After getting my compressor to go by placing a heater in front of it around mid-day, I thought I would have a go at doing some flowers or something to use up some off cuts. I started making a rose and went to use the angle grinder. It wouldn't work. So after the usual shaking, followed by tapping, then hitting I started to strip it down. I thought I would put the volt meter on the switch to see if there was juice getting there, that was fine, so it wasn't the lead. I undone the screws to release the mains lead from the switch, so I could check the wires leaving the switch when I grabbed the ends of the lead
I had left it plugged in the socket! Damn did it give a whallop, followed by a numb arm and all my insides on edge!
he then proceeded to cut the cable to length, you can guess what happened
