julianf
- devon, uk
So, I'm trying to do a work room here that will be slightly in the 'fancy' side. It will get called a 'studio' or some other such name... You get the idea.
I'd like to use these lights -
The reason being that there are a load of joists almost at head height and I figure I can run these in the gaps between the joists. Ie one set every gap, or every other gap.
Here's the link for the product -
https://www.wayfair.co.uk/lighting/pdp/paulmann-mac-ii-5-light-track-kit-pun6821.html?piid=21840103
But then I'm guessing I have to buy the transformer and bulbs separately, right?
There is minimal clearence over the top of the units, so I'm wanting low wattage led - I'm assuming that is safe?
And do I get one transformer for all the sets (probably 3 or 4 total) or one per set?
I don't have to buy what's in the link at all. Seems a lot of money (£250 ish for 4 sets) for some bits of wire and pressed metal from China. If anyone knows something similar for cheap, I'd probably be ok with that too, but needs to be fancier than florescent strip lamps... And surface or wall mount - loft floor boards directly above with no cavity at all.
Thank you, as ever... : )
