I buy Clarke 180en welder from ebay..but welded spot is too weak.
http://www.ebay.com/itm/Clarke-180E...20683781117?pt=BI_Welders&hash=item4aaa3e2bfd
I use many type wire at first I use CO2 flux wire.. I learn its wrong
So I change to CO2 non flux wire with CO2 gas..
I'm living in Korea.. In Korea most wire welder is CO2..
But still it's weak..
So I buy mig wire from ebay..
http://www.ebay.com/itm/220981166445?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
this wire...
But It's same too weak
Gas pressure is 15 (It's weak I know T_T) I adjust max and 3 the maximum power of welder
I weld a spot as normal concrete nail's thick..
But It's easily broken but broken spot is very clean no hole..
What is wrong??
IS this wire problem? What wire I must buy...
Or It's normal??? Is welding spot is weak as this?? I just weld it and I use my hand I can break It
Oh... I clean metal before welding with my grinder..
And this is just for showing... and It's not problem of attachment of welding wire ...
It's matter of welded wire's strength.. I make a line between two bar and it's middle is broken easily and broken section is very clean.
this wire...
What is wrong??
