Hi
Has anyone tried it? I have a torch that only take m5 contact tips so the max size tip I can get is 1mm and the ally wire is 0.8mm (unless someone knows of a 0.6mm supplier) will that be enough due to the expansion? Also can you try out welding it with CO2 or a argonshield type gas. I understand it should be a pure type argon shield gas but I was going to try and play around with some 3mm off cuts to see what I could do.
What do you think?
Thanks Tim
What do you think?
Thanks Tim
