Wallace
- Staines, Middlesex, England.
Wallace's off where
I sold it to CJ.
Wallace's off where
The only downside was the 20 odd fasteners holding on the undertray.no need.
Vacuum extractor is the way forward, I use an air powered Mityvac one. They are a chunk of money but makes quick jobs like these a dream, with modern runny oils it will suck 5-6L out in a few minutes.
Only downside is it's very disappointing when you get a car that has a narrow diameter dipstick tube, I couldn't remember the last time I took a sump plug out until we bought a 2002 Golk as a spare car, dipstick tube is too small and I had to get oily.
How do you know the pipe you put down the dip stick hole finds it way to the lowest part of the sump. Also how do you check the oil for contamination etc
There is a bit of experience required for each vehicle, often the sucker tubes have a bit of a natural curve so by rotating guides takies them in a different direction. There cars that are a pain. Discovery 3 TDV6 has a convuluted section which make putting the tube in fiddly and I previously had a cheaper unit that just wouldn't do it.
I appreciate not always but most of the time the dipstick goes into the deepest part of the sump
It's often be said to me that they don't get everything out but if you look at any sump plug there is always some kind of lip that leaves some in the bottom, the sucker can get this out.
Once you used a good one of these you'd never go back to the old way and you far more likely to change the oil regularly when it only takes 10mins and you don't get dirty. I only change the filter every other time on my vehicles because I'm halving the oil change interval anyway.
Are you aware; oil filters filter less the older they get. The fibres in the filter breakdown, releasing any held contamination along with the filter material.
If I'm changing the oil I'm changing the filter too so the undertray is coming off anyway and I like to have a quick inspection for leaks etc, up on the ramp it's no great deal.
Every 3.5k miles on the Subaru![]()
we’re way off track I know but Ive been looking for one of these for my dad. He’s late 70s and getting down on the ground to do sump plugs is becoming a strain - but he’s fastidious about oil changes. A sucker system sounds just the ticket. Any recommendations ? Interestingly he always taught us the same - filter every other change. But that was doing oil at 5k km. modern ones are saying 20k miles or more I think?
Both our daily drivers have the filter at the top of the engine so there no need to go underneath anyway. Even if you do go underneath to do the filter it's still less hassle sucking the oil out than draining through the sump plug.
I've got a 2 post and a 4 post at home but I still use the vacuum extractor
Different strokes....
I've got a little oil pump but I'll stick with the sump plug.![]()
.8 or 10 kva
Petrol 10kva is the one i am buying
What's the priceI have a contact that did me a great deal but not sure re shipping to you.
Still off topic, Smart cars don't have a sump plug (I'm told) and newer Jags have a tube in the oil filler neck for the sucky tube. On my DS to change the oil filter, remove 8 bolts from sump plate, oil pours out up to your armpit, if you don't align the arrows when replacing, oil starvation and seized engine. Time to buy a sucky thing!
I had Sealey or maybe Laser one before that was air or manual pump, it worked fine and I did many changes with it. I have a Mityvac MV7300 and it's way better than the old one I have, it's air powered and they do cost about £150-180 if bought in the UK but there is a manual version MV7400 which can be bought cheaply. Interestingly the ones Snap On sell are Mityvac units.
I guess the only issue with a manual one is there is a bit of effort involved in pumping.
