Myles1970
- Monaghan, Ireland
Well folks, it's been a while....
Having knackered myself hammering a press-fit bearing and retainer onto an axle half shaft (using a metre of pipe), I've decided to build a press. I'm thinking of a fairly simple design, using a 20ton bottle jack and a length of channel. I've seen various designs on YT, some simpler than others. I want it to have the ability to press bearings onto an axle half - shaft, so probably channel set back to back as a base with some thick plate pieces to allow for adjustment.
Any thoughts? Has anyone here done it? Any advice before I order a 20 ton bottle jack and a length of channel?
..... Also, I have some 4x2 box that I used to make a jig for a car that I no longer need. Perhaps I could use it to make the uprights as they wouldn't be under lateral load so much as tensile tension (if that makes any sense)?
