Heat, Hit, Harden, Temper, Grind!Can anyone explain the process of this file to knife thing...sounds very interesting![]()
Basically heat to red, quench in water or oil, polish then temper using the colours. You need to decide which way to compromise, harder blade means more durable edge but more likely to chip or break, but softer will need sharpening more frequently. Probably somewhere in the purple/blue area.Also how did you harden and temper the blade
Im away this week and was planning to have a go when I get home. Couple of weeks ago I picked up a small kiln/furnace that goes up to 1800 c, itching to give this a goBasically heat to red, quench in water or oil, polish then temper using the colours. You need to decide which way to compromise, harder blade means more durable edge but more likely to chip or break, but softer will need sharpening more frequently. Probably somewhere in the purple/blue area.
skin a few catsWhats there to hunt in Wolverhampton?![]()
May I suggest that you make the thong ( the long bit where you thread your belt through ) of the sheath an inch or so longer than the handle .please critic.
My first fixed blade hunting knife mad from old file ,sheath from an old laddies saddle bag,
hope you like it.
It was a hedge row find i think it is hawthorn, the branch had been lying there for at least two years seasoning.
Cut it of with a bacho saw. draw knifed it to a blank put it in boiled linseed for a couple of weeks.
I like the way it turned out .
Every time I walk the dog I collect a little bit more for stock.
