Hi,
I have been dodging this for quite awhile now but the time has come. I spent a lot of time going through the "Best Welder to Buy" posts and the general view is the Portamig 185 is the one to go for if you have the funds. The day before I was going to order I came across the below Oxford 200-1. The reviews for this were also good being made in the same factory. I rang a place in the UK that had one in stock with cheap shipping to Southern Ireland so jumped at it. Came with regulator and torch. I also got an auto darkening helmet. I got some gas and 5kg roll of 0.6mm wire last week. I also have a 1980's Fiat which is not disappointing in terms of welding.
First thing is to practice so have a sheet of 1mm mild steel. For light steel I think I am supposed to set welder to 20A (which is lowest setting, Portamig does 15A) but how do I do this. Below is picture of the knobs on the front panel. The wire feed is variable by switch on the right I think so suppose will have to mess around to get it right. It didn't come with instructions as I suppose you are ment to know all this.
Can anyone give me some instruction.
Thanks.
Thanks.
