finyuk2005
thats more than the silicone welder can fix...True, I've got the t-shirt for that![]()
Not at all, just get a bit of rustythats more than the silicone welder can fix...![]()
If waters coming in, then anything over the outside will help.Not at all, just get a bit of rusty
plate slightly bigger than the hole you've just made and appply bathroom sealant liberally to the back then slap it on, jobs a good un![]()
That will go down wellSaw this online, some bloke is DIY overplating his narrowboat , the welds look " interesting "
View attachment 439021View attachment 439022View attachment 439023View attachment 439020
water pressure pushing against it will help hold it to the hull...Not at all, just get a bit of rusty
Hope you were on dry land and not in the water when that happenedTrue, I've got the t-shirt for that![]()
thats true, with a big enough drain hole at the back and enough speed it will all just fall out!I really don't know what all the fuss is about, after four pages of messages why do we not understand that it will be absolutely fine when it 'gets up on the plane'.
A lot of wet dingies work that way!thats true, with a big enough drain hole at the back and enough speed it will all just fall out!
Jet skis have drain plugs which are sometimes left open and not screwed back in the next time they are on water.A lot of wet dingies work that way!
They also have a drain bung too...not fun when you forget to put the bung in!
oh yes, dad did that last yearA lot of wet dingies work that way!
he did manage to beach it and get the plug back in before the journey back homeThats what buoyancy bags were for!A lot of wet dingies work that way!
