brightspark
- yarm stockton on tees
The idea is you take off the caps to use it, then stickem back on when finished to keep the water in for storage.I bought some water levels from Amazon. They worked fine, once I'd drilled a hole in each end cap. They were sealed, making them completely useless as levels......
No, but it does mean that you can fill them up before going to site, sometimes water is not available.I thought they might have been for the Australian market, to stop the water falling out.
Just to clarify. B&Q is known as Brico Depot here, same Kingfisher parent co. So I imagine the kit is the same as UK?
Water levels are 100% reliable and cheap
Surely better to empty them, or the water will go mank.
You need to use properly calibrated water.
I've got some but its expensive.
Let you have some for £10 a litre mates rates.
Dont you have a hose pipe, if so just put some clear pipe on each end and job done
the sap[
