I need to butt weld a 1" 3.2mm wall tube to piece also 1" but approx 6mm wall.
Should I bevel the tubes ? I typically only use 1.6mm rod as it's mostly 3mm or less I weld. If I bevel should I go up to a bigger rod to build up the joint or should I do a root pass then a weave to fill any bevel ?
Useful for certain jobs perhaps, but not exactly great to use especially when coming from 3.2's!
