badabec
- Essex UK
Hello, this is for the pram top for a Citroen DS Decap, the mega expensive one.
The pram top is dead simple. The 'bearings' consist of holes in arms rotating on pins, about 13mm diameter.
The holes have elongated. Plan is to drill out and ream all the holes to a standard size. Then make bronze bushes which will be shrink fit.
The problem is the pins, they have various degrees of ovality.
Because this car has hydraulics opening and closing the rag top, the pins are welded both sides (forces involved).
How can I overcome the ovality?
I can't spin them in a lathe, it would need a massive swing.
Are there tools with for example three grinding wheels that could slip over the pins? They are only 3/4" long.
Any ideas?
They don't want remove the pins for some reason.
I'd rather make new pins, but, hey ho.
With the manually opened rag top, you can feel if it snagging and adjust the pull.
With hydraulic one it just carries on regardless, no safety stop and needs manually turning off at the end of its travel.
Any ideas?
