Melvyn Best
- Cambridge
A scotch pad cleans ally pretty well BUT do not use on ANY internal surfaces Apparently boiled rhubarb leaves clean ally
Slightly different , but off the same thought
Lobster cooks really well in the dish washer ,,, no soap etc of course ,
wrap it up in silver foil ,, and run the washer , steamed to perfection.
just sandblast then 1st it strips the surface and leaves a clean matt surface. as u say beads peen it and close the surfaceIf you want to weld the parts whatever you do don’t vapour blast first.
The part needs to be cleaned in a hot detergent solution, like a professional hot water parts cleaner, then rinsed and cleaned with a solvent, then you could bead blast it/vapour blast it.
If you bead blast or vapour blast first, it peens the surface of the aluminium, locking in the dirt and oil. The part appears visually clean but when you light up on it and form a puddle, it immediately becomes contaminated.
Aluminium has a surface oxide that is very tenacious and by vapour blasting again you are locking in this oxide.
This also occurs if using flap wheels, wire brushes that spin too fast or other abrasives that smear the aluminium.
Anyone tried Oxalic acid ?
You can buy a product from AutoSmart. There’s two strengths, I’ve only used the weaker one as I don’t really like dealing with Hydrofluoric acid!
It’s called AluShine and AluBright.
it’s very powerful and does require agitation. Whatever you do don’t let it dry on.
brought up the aluminium bed of his transporter like new with just a spray over and pressure wash... unbelievable stuff. Looked at the label... hydrofluoric acid... no wonder
My cousin (car dealer) has started using the stronger one, it's LETHALbrought up the aluminium bed of his transporter like new with just a spray over and pressure wash... unbelievable stuff. Looked at the label... hydrofluoric acid... no wonder
Don't transfer it to a glass bottle, hydrofluoric acid eats glass
