RIP
Kairo
- Netherlands
Soon I will be blasting my stripped down car body and thought that if I remove the windscreen then I won't need to worry about masking it off and I can paint epoxy under the windscreen as well. Some of the blasting I need to do is quite near the windscreen so I would need to mask it with plywood even.
This is an old Suzuki. I can see that the windscreen sits on two plastic snails which let you adjust the height of the screen in the recess.
The glue is available on eBay.
I've got some Sealey windscreen removal tools:
And also some windscreen removal wire:
That's a job I've got to do on my project in the not too distant future.....
it was replaced by insurance.
my windscreen was burnt by someone cutting iron guttering with a stihlsaw
a month later someone pulled out across me and hit the front end and a pebble came up and cracked the screen
