i wouldnt wurry about being registered it makes no odds if u are doing it yourself as long as the jobs done correctly
but i stress the job must be right and complythe socket on your cooker unit is 13 amp the sockets round your house are 13 amp they will both be fed of a 30 amp supply if the house sockets are on a ring main .if u intend just plugging in a 13 amp plug in to a socket the 30 amp fuse back at board is ok. if u intend to conect a 16 supply to welder socket back into the rear of cooker unit the board fuse needs down rating to 16 amp
and a standard euro torch from a mate (the small torch supplied is ok but im used to the industrial torches).it was probably a b type breaker should have changed it to a / d type 20 ampI bought my welder specifically because it runs on a 13a supply. Its a buttersuk weldwizard 180 and will comfortably weld on full power (decent amount of grunt too). Been welding 16mm bar to 5mm angle (approx 20 second bursts) with no problem, not sure how long it would weld continuously on this setting but dont want to purposely toast anything. Eats through 2mm all day and is really smooth.
Its a bit 'lightweight' in design so im building a trolley to slot it into and will sometime have a couple of strengthening panels fabricated. The unit itself is light enough to lift comfortably in and out of the car. Got a pub bottle full of argoshieldand a standard euro torch from a mate (the small torch supplied is ok but im used to the industrial torches).
The only issue i had was it tripping my 16a garage mcb so electrician has swapped it for a 32a as it worked fine from the house ring. it tripped this new 32a initially so we tried it with an 8m extension lead and it doesnt skip a beat (garage cu is 30cm from the plug socket). Anybody else had this anomole ???.
probably sh i ,..,/.,/tty electricsIt is a type B (as is the new 32a) but i couldnt find any others for the cu. Its a volex one from screwfix with two mcb's and an rcd.
Does anywhere stock Type C/D mcb's for this unit ??
city electrics
hager are the same fit as volex
