p.s. do you have the cleaning tool already? can you test it on your compressor and turn the valve on the compressor up/down to see how much difference it makes?
there's a chance lower flow (to a point) makes naff all difference
I've managed to figure out that it works between 90 and 65PSI, so whacking the compressor on 90 and ending up with a number somewhere in that range should be fine.
10mm hose gives a drop of 7.5PSI, 12mm 3PSI and 15mm 1 PSI. So I reckon for this particular tool 10 would be fine, but I'll probably go for 12 or 15 to cover whatever else might be on the end of it, depending on if there's a meaningful cost difference at 50m / maybe getting a 100m roll and chopping it up...
