Tinbasherdan
Bodger in chief
- Bolton, England
Yes that’s the dingleberry type! I’m leaning towards those at the moment as I’ve seen a few using them. Issue the first is to get the engine unseized. Seems it got unsheeted while we were moving house and it was being stored, and waters got in the intakethis is what I am thinking of and got with lathe forgot the proper name for it cheers seadog
Just be careful, you can make a bigger mess of the bore with a hone. The centre can end up larger in diameter than the top and bottom, beer barrel shaped.
I always use the 3 legged sort.....I have sorted loads of old tractors with one of these......
It's easy to concentrate on the extremes of the bore to get em better looking.....
they wont remove the ridge.....BUT can u still get ridge dodger rings......?
Dont know about Cummins but there s plenty of engine rebuild kits for all kinds of engines and most are very good...
they all seem to made in India......I have fitted loads and never a problem....
A proper hone...At this stage the bore needs a clean up just to expose possible water damage, those two shilling three legged things and a bit of paraffin would do that job. If its rescueable take half a thou out of the bore with a delapena and put it back together, liners are cheap so I wouldn't spent too much time musing over it,
Bob
A proper hone....
And a Wolf gut buster to drive/turn it???
RE liners- the Cummins 6bt doesn’t have liners, it’s a machined block so if it’s beyond saving it’s paying through the nose to get one or two cylinders over bored and matching pistons inserted. I’m hoping the damage won’t be too great as it can’t have sat for that long
Talking to a Cummins designer that worked on the 6bt he reckons that repair liners can be a bit hit and missDan, overbore any duff cylinders to take a liner and bring them back to standard, no new pistons needed.
Bob
