On the one with the yellow jack it looks to me like the right hand side of the slot is in line with the right hand side of the pin holes and as they are a different size it means the roller is offset to the right.
I think we need to be careful saying the jack needs to move, I would say the postion of the slot the roller moves in is more important.
Looks like the test pipe is too short. A longer pipe would give you more leverage. The bend starts because the front clamp lifts up one end of the pipe so that it is not parallel to the bed of the straight die. As the die comes up straight and in line with all the pivot points yadda yadda, because of the slight angle of the pipe, it begins to bend around the upper die.
It's about now I would be on the phone to Stakesys with my credit card![]()
Have you tried pulling the tube so the die is already pivoting before enagaging the jack to see it makes any difference?
Ive been tempted for a long time. Maybe my next big purchase before I retire. (Only excuse i can think of at the minute)It's about now I would be on the phone to Stakesys with my credit card![]()
I might have a bit of the answer... I think it relies on the u-clamp holding the tube tight to the top die at the very end. So that where the jack applies pressure the tube is slightly clear of the top die - giving a start to the bending action. If that clamp is loose or the tube fractionally undersize then the tube will just tilt a bit and the whole thing lock up solid..... Does that happen? Does the tube tilt from horizontal as you crank up the jack?
Is the tubing the correct diameter for the die and follower? Are the dies Imperial and the tubing Metric? There must be some triangulation offset between the roller pivot and the die pivot where the force is applied for the bending action to start. The triangulation offset would be the contact area on the tube between the die and follower. Tightening the bolt against the tube with the clamp hoop fitted sets the triangulation offset by taking up all the slack in the pivots and effectively starting the bend, the tube should now be sitting at a slight angle to the bender and the die rotated a few degrees. Pumping the jack then squeezes the tube out around the die as something has to give way and the tube should be the weakest link. If the tube is smaller than the die and follower the triangulation offset will be reduced needing more force and may crush the tube. Did the clamp hoop come with the die set or did you make it? Everything I can see in your photo is very well made and I'm wondering if the tolerances may be a bit too good! If the clamp hoop pivot is spot on so the tube is almost flat with the die the triangulation will be reduced. Moving the clamp hoop pivot a little further out should increase the triangulation angle as the die will be rotated further with the bolt.
(The joys of using a mobile phone to post, Dee J posted while I was writing)
Were did you purchase the die set from
