Kram
- Sussex
Inductions best if your cooking involves boiling pans - soup, potatoes. Quickest way to get heat into water.
Very good with cast iron to cook steaks or frying. Get a sillicone heat mat to insulate the pan from the hob. Anything hit and it takes ages for the glass to cool down, bleeps if you wipe too soon, annoying as I cook in the early hours very often and always clean up before I eat.
Induction has disadvantages, glass tops easily stained or overheated. Do not use enamelled cast iron for frying steak as you can get hot enough to transfer the enamel.
Induction bleeps at you. If you turn it on and remove the pan it'll complain. Pause it for 20 seconds and itll go off. There is a timer, never used it.
Woks. Yet to find a good one, you essentially want a massive high sided, flat bottom frying pan to do stir fry on an induction hob.
Deep frying doesnt work in a normal wok, not enough aurface area and the oil will bubble like crazy, well below temperature.
