Hey there,
Had some trouble recently with my migmate 150.
Started with the wire feed motor giving up (burnt out)
Bought replacement and fitted it,
Fed wire back through, got snagged in the torch so I took that apart to help the wire through. Put torch back together and all was working, wire feedind well.
Went back to garage to test it and was welding fine for about 5min untill smoke started coming from the torch (trigger).
Then It wouldnt stop feeding wire! untill i switched the machine off.
Now evertime I stitch it on it feeds out wire without me pressing the trigger.
Took trigger apart and put it back together properly and with more care but it hasent solved the problem!
Help!
Help!
