brightspark
- yarm stockton on tees
the only advantage u will gain is a simple push of the buttons to stop and start rather than turn a switch
I can hit quickly, in case something jams or goes wrong...
If you were to add new DOL starters you could those existing switches as remotes if they are in better position, but without a DOL unit or additional contactors they aren't much use to you.
PS i would double check all the existing wiring as it looks as if earth wires were used as switching wire in the photos you never know what else may of been played with.
