I have a very old compressor (areograph) that I’m trying to restore. It has no check valve and the main compressed air outlet from the pump goes straight into the tank. There are a couple of small pipes coming off the piston head, looks like on top of the inlet valve side of the pistons, they are broken off and do not connect anywhere. From old photos on the internet of similar compressors, it looks like these used to connect into the tank too via a separate connection. In which case I don’t understand what they’re for, and also how pressure from the cylinders is released when the motor stops...? Looks like this is designed to add pressure to the cylinder head (on the inlet side) rather than take it away? Can anyone advise?
