) then I can flog it instead of skipping it.
) also failed to work once emptied and cleaned
Actually depending on the rating of it, a normal hand portable 110v site converter brick would probably run that. You can find them secondhand fairly cheaply usually if you keep a eye out for one.a huge American dryer (unusable as it needs a huge expensive transformer to make it work)
I'm all for mending and making do.
You'd be most welcome, choice of 2 Panasonics with stands and a Grundig.220wNice work Fluffy!I'm all for mending and making do.
Re; the american dryer, I did sort of look into it when I first lumbered myself with it and seem to remember it required stupid money. It's rated 220w (has a huge american 3 'pin' plug welded on) but the cycles are different to ours.
Think it requires something hefty because of the heating element, a washer would need much less.
However I'd be happy to be proved wrong, I'll have a look at the plate tmw and post up the details, maybe someone on here can advise...or maybe there's a member on a US base over here who can get a cheap transformer??
Om - TV's are pwo but have been superceded by digi ones - why you wanna drive a few hundred miles and collect one?You'd be most welcome, choice of 2 Panasonics with stands and a Grundig.
Might get a few quid on fleabay if I can ever get myself together enough to sell instead of just BUY.
more like 2.2kw even thats small for a drier220wmore like 2.2kw even thats small for a drier
ps america is 60 herts english 50 herts will still run though
I meant VOLTS of course Most electric dryers in the states are 220/240v, and are plugged into a 30a socket.It's an Amana (from memory), know anything about them?
Cheers again guys, spent a little more time scratting at an old spade connector and finally got it opened enough to attach the wires properly, machine now back in place, hall cleared of tools and tears just waiting for the day I have too much wet washing to sensibly hang on racks by the radiator (having lived all my life without a dryer it will take a little encouragement to get me to run up my leccy bill!).
New tenant just been round to say the washing machine I said they could keep (also left by last tenant) was broken and could I dispose of it for them. As he reckons it's only the belt I feel inspired to fix it (now being an expert in such matters) then I can flog it instead of skipping it.
Every cloud as they say
Heaven knows what the last tenants did with their machines, broken washer AND dryer and the fridge freezer which was working when they left (and still full of food) also failed to work once emptied and cleaned
That was also returned to me and with that and the washing machine, a huge American dryer (unusable as it needs a huge expensive transformer to make it work) another fridge freezer I cleared from my mother's lodgers room and 3 redundant televisions all cluttering up my hoist room, I'm beginning to feel like a s/h appliances shop![]()
Ratty,
That American drier...
Apparently most have 110 volt and a 220/ 240 volt option alteration in their wiring .
Father in law in Canada surprised me when he showed two phases of 110 giving 220 volts driving their drier.
u need a 6k transformer 6000wattsOnly just seen all these helpful replies about the Amana.
I've checked the plate inside the door and it gives the following info;
3 wire circuit
120/240 v
24 amp
60hz
5400 watts
Robert - sorry that diagram doesn't mean a lot to me
If I knew what sort/size of transformer it needed I may be able to get one through a mate in the village who works on one of the US bases.
i had a 4kw thats why i got big b ,.,.,.s lifting it mind u if its dual voltage it will probs run on 240v
