Good day all, i purchased a brand new "YESWELDER" helmet from Amazon. Rather a budget one but seem to have had good reviews from others. I thought that since I am just playing around in my garage it would suffice. When pulse option on the welder is "ON" everything works great. However when the pulse is "OFF", darkening turns on and off about every few seconds during welding. I tried replacing batteries and playing around with the sensitivity settings but even at max setting it doesnt stay 100% on although better than at 80%. Not sure if they all perform like this or only sub $100 ones. Please let me know your experiences if you had something like that happen to you Thanks
I assume pulse mode is on the welder? Try leaving the lid (or the weld side of the auto darkening lens) in direct strong sunlight for a day. It might sort it out. (it did on my expensive Miller lid) If that doesn’t help send it back, it's faulty.
Yes sorry i just edited my post to add that clarification. The pulse mode is on the welder. Looking at direct sun turns on the helmet for about a second and turns it off. I don't have experience with any other model or brand but I thought that it only supposed to respond to a flickering light of a weld and must be turning off if it senses continuous light. Like I said I have no idea how they are supposed to work.
Many low cost helmets are not sensitive enough for DC tig work, they work with AC and pulsed DC because it is quite electrically "noisy" for want of a better description, the raw DC tig is just too smooth to keep it latched in to dark mode,
Ok so i left it out in direct sunlight just now for an hour and absolutely right, it did improve. Looking straight at the sun doesnt flicker it anymore. I guess there is some charge inside in addition to the battery??
Try increasing the delay time if your mask has this option. I had the same problem with my new tig in when welding DC. The delay keeps it dark for that little bit longer till the mask decides it still should be in dark mode
Leave it in the sun all day. There is probably a rechargeable battery inside it and the solar panel on the front charges it up. I expect it's been sat in the box in the dark in a warehouse for a while.
Thanks everyone. Mine was faulty. It did work as expected for few minutes after "charging it" but then started doing the same thing even looking at the sun. Replaced it and now all is good.
