N
naughtyboy
Guest
is it cheaper to keep heating on all time on low setting or just put it on higher when its needed?
cheers
cheers
You would have thought there would be a sensible way to do it these days what with heating oil costing so much.
as said underfloor heating is ok mainly just used over concrete and wooden floors that are tiled . they run at 100watts per square meter . ijust wired a load up in someones house total load 8kwTime to heat a building depends on many things. I installed the heating circuit in this house the mains in 28mm feeding manifolds to individual rads using 12mm and 10mm.
So if a rad is either off, or at temp that leg does not get used, and hence the water doesn't require heating thus speeding heat up times and saving gas.
All the rads in the house are hot within 15mins. The house is a large 4bed semi.
As for underfloor heating, you have to remember this is intended as a background heat source. To be supplemented by other means if and when necessary. This is because the heat supplied by underfloor heating is slow release, and cannot react fast enough temperture changes.
i wouldnt fancy there bill along with the boiler radiators and aga
me neither . the pipes are evenly spaced and each room is run of a zone valve and a thermostat . the water ones that is . electrics the same. run of a room stat and theres also a probe in the floor wired in between the elements . so it takes the temperature of the floor and the room as wellI've never heard of hot spots?
