gaz1
- westyorkshire
In an effort to beat the condensation/rust i want to install a heater under the drawers in my lista cabinet, theres probably a 40mm gap. What sort of heater would be best? A tube heater or something along those lines or a heat pad?
Ah i see those enclosure heaters go up pretty high. Could do with something thermostatically controlled really
you would also need to close off your 40mm gap as referenced above
you also need to set your thermostat higher as the tools would need to soak up the extra heat before they get warmThe heater only needs to heat the toolbox up to 15 degrees odd and that would stop any moisture from forming during rapid temperature changes.
now that heater may not do what you want but you could use
underfloor heating wrapping it around the shelves and sides
you may know what that feels like if you have it installed you could also thermal mass it with a few tiles in the bottom or on the shelves
it does transfer to tools this way as my metal spanner heated up while on the floor
