Tinbasherdan
Bodger in chief
- Bolton, England
That’s an intriguing setup! I’ll take a look at that
Cheap as I can get itPrices vary as similar set-ups are used on Jensen, Aston Martin, Rolls Royce and some Italian stuff IIRC.
They’re quite bulky in comparison, I’m trying to gain clearance on the body xmemberCan you not use a complete modern caliper with handbrake?
Theres a few motorcycles that came with cable operated brakes that might be an option ?
It is, yes. I want to replace the original drum hand brakeI this on your Land Rover?
Yes, as it stands the handbrake drum is about 5mm away from the body xmember, I want to give it a bit more clearance.Dan, what are you after? I assume shorter distance front to back rather than smaller diameter?
