Tinbasherdan
Bodger in chief
- Bolton, England
That’s an intriguing setup! I’ll take a look at that
Cheap as I can get itPrices vary as similar set-ups are used on Jensen, Aston Martin, Rolls Royce and some Italian stuff IIRC.
I’ve found a Wilwood spot caliper , bit more reasonable than the jcb callipers and similarThey’re quite bulky in comparison, I’m trying to gain clearance on the body xmemberCan you not use a complete modern caliper with handbrake?
Theres a few motorcycles that came with cable operated brakes that might be an option ?
It is, yes. I want to replace the original drum hand brakeI this on your Land Rover?
Yes, as it stands the handbrake drum is about 5mm away from the body xmember, I want to give it a bit more clearance.Dan, what are you after? I assume shorter distance front to back rather than smaller diameter?
