The master cylinder is inside the box section with access from above by removing a bit of floor. The jokers at BMC put the bolts, which go right through the box section in, so that the heads are behind the torsion bar, so you either had to saw the bolt heads off or remove the torsion bar to get the bolts out. Had they put the bolts in from the other side it would be no problem to remove them.
