- UK
There's an annoying weap out of the oiler plunger on the apron. Its not the internal part of the plunger as i've had that out, changed the O ring and sorted that one. The bellows leak is fixed, and the bottom plate resealed (which was also weaping). I left it as it was hardly weaping but 24 hours a day means there's the contents of the Exxon Valdez sitting in the tray.
Can i avoid taking the top slide off? Theres four cap heads from the top of the top slide into the top of the apron. If i release the lead screws and take these four cap heads out will it just come away? I have the exploded diagram but it just shows each piece in isolation.
Or...will the offending bit below come out of the front of the apron? Its the larger of the two o rings that will be leaking.
