hi
I have been using my 41/2" grinder today. it has started to run slow. It's an old green and orange black and Decker.
is the motor burning out or maybe a strip down and clean?any ideas![]()
hi
I have been using my 41/2" grinder today. it has started to run slow. It's an old green and orange black and Decker.![]()
no smoke just started to slow down.
ebay for brushes?
grinder slow, may need a new phone!
Beat me to it i normally say delete and re-install the app ..grinder slow, may need a new phone!
Cut the suppressor out, the worst thing that happens is you will wipe out the radioI had a similar problem with an elderly Bosch jigsaw, the cutting speed reduced and it became erratic in operation. Turned out to be failure of the suppression capacitor, the only place I could get an original one was from Germany at about £12; eBay came up trumps for about £1.70, wasn't identical (same spec) but it worked fine and continues to.
nw grinder time we get it all the time at work when they start to play up if its anything other than the flex its bin time , we did go through a time of getting brushes for them, but its such a pita getting the boss to order brushes its easyer to add grinders to supplyes order and get moaned at. put brushes in them they go for a bit but they never go for that long 2nd time around
I remember the time i told someone not to run a 110 on 240,but he said it'll be ok because the extra voltage will make it more powerful,but he knew best,hour later i didnt answer his call as i knew what he was about to ask,"can i borrow your...........",on your bike mateYou're not trying to run a 220v grinder on 110v are you?![]()
