Hi,
I need a new grease gun. Again. I seem to really struggle. They stop working after a couple of years, take it to bits and clean everything out and nothing seems wrong, after that it will OK for a bit then need to do the same again. The car parts and tool shop guy says they're all like that, you just have to treat them as consumable and replace every few years. So greasing the snowblower the other day my normal gun is now going the same way, won't work once the cartridge is down to about 1/4 without a lot of faffing around.
Does that sound correct, or is it just because I'm going cheap? Normally at the sort of "Draper" price, although the one for the digger is actually Hilka. If I go up in price will I get something better, if so any makes recommended? I did try a slightly more expensive one once but that was completely useless - the spring wouldn't stay retracted so before you quite got it loaded it would suddenly release and shoot grease across the shop.
What I really want is something I can hang up in the garage knowing it will work straight away when it's needed. Just now things get neglected because I know it will mean wrestling with the thing.
Thanks, TS
Thanks, TS
