pointer2null
Ready, Fire, Aim!
The regulator arrived from weldequip today and it's all fitted fine.
Started to have a practice weld and there seems to be something up with the welder.
At first it sounded like this Normal (on but not welding)
Then after about 5 minutes it started doing this (again on, but not welding)Lots of noise
When the noise starts the gas flow reading drops as if gas is flowing. If I pull the trigger to start welding the noise stops and it just sounds like it did when I first started.
During the times is wasn't making a racket, when I pull the trigger I can hear gas escaping where the torch joins the welder. Is this normal or are there more problems?
About the only thing that does work perfect is the regulator
