stuvy
Only slight problem is the screw catches the visor making it hard to tighten
washer?
The screw to hold the go pro on the mount?washer?
See what I meanWith out seeing it it’s hard to know which bit won’t tighten up
Could but wouldn’t be as easy to change when outCan you not put a normal m6 in?
Got it a bit better just put some rubber between the mount and visorRock and a hard place, then
You not still got the lathe ?Got it a bit better just put some rubber between the mount and visor
Yeah I still have it what you thinkingYou not still got the lathe ?
That a small block of aluminium, your lathe and a couple of end mills you could make one, granted not as easy as on a mill but doable.Yeah I still have it what you thinking
I’m not followingSo what did you video?
This one ain’t for a bike it’s for my jet ski but can’t get out as every where open local and semi local has made it members only and you had to be a member before covid to keep goingDid you go out on the bike today?
Sorry I replied without looking at the thread again, I probably meant to say you could make a screw of any length you want even if you don't want to or can't make the mounting block.This one ain’t for a bike it’s for my jet ski but can’t get out as every where open local and semi local has made it members only and you had to be a member before covid to keep going
Never had to be a member of the sea before to take a boat outThis one ain’t for a bike it’s for my jet ski but can’t get out as every where open local and semi local has made it members only and you had to be a member before covid to keep going
Don’t have to be for the sea but to use the slipways go get access you doNever had to be a member of the sea before to take a boat out
A lot of the slips are club or council run now Dan...i live on a peninsular with water on 3 sides but only 1 decent launching slip and that's only access onto the beach..cant use the slip without level2 and insurance for your permit..never has it been so hard to access the sea as the last 5 yearsNever had to be a member of the sea before to take a boat out
other areas may be different..sorry for the rant lads but it boils my water this subject
Same here really annoying especially since there all open but only to people who renewed their membership before the covid situation started anyone after that isn’t allowed to join or launchA lot of the slips are club or council run now Dan...i live on a peninsular with water on 3 sides but only 1 decent launching slip and that's only access onto the beach..cant use the slip without level2 and insurance for your permit..never has it been so hard to access the sea as the last 5 yearsother areas may be different..sorry for the rant lads but it boils my water this subject
