hello all,i have posted on here b4,but am still new to welding.i recently bought a mig welder of unknown make,but most likely its either an early clarke or early sealey.i think it is a gas only welder as there is nothing on the front of the welder to allow easy polarity change.i have bought a small reel of gasless flux cored wire so i can have a go outside as i have no garage in which to practice.i have been told i shd b able to practice ok with this with the welder set as is,however ive also been told it wont b very good because the polarity needs changing for gasless wire.i have pulled the top of the welder off to see if i can do this from inside the welder.i have taken a pic and added a couple of notes for which lead goes where.am i being naive by thinking i just have to swap these 2 leads around to change polarity? the clamp for the earth lead will loosen to allow the lead to b fed into the welder further,allowing it to reach the back,i kno this will shorten the amount of lead on the outside,but dont think it will leave it short enough to become a problem.
heres the pic...
hopefully it came out ok,and someone can tell me if swapping these leads will make it perform better with gasless wire.
thanks in advance for looking and for any advice given.
neil
heres the pic...
neil
) on here who most likely find text speak quite difficult to read.
