Smallfry
HE's Spartacus.
- Kent UK
With my ongoing BMW six cylinder M57 diesel clean and minor refresh, I decide to renew the glowplugs. Always a worry when they have been installed for some years, in this case 20 years, original set. Have applied Plusgas over a couple of weeks to help'
Gingerly apply torque gradually, and hope they come undone without snapping off, or stripping threads in the ally head. Four came out, but two snapped off flush with the head. No surprise really, and wish I had left them ..... as you do.
As easyouts only tend to expand the body and make them tighter, they are not a good idea, and being hard, if it snaps, you really are stuffed, I will not use them. So drilled down the core with a carbide drill bit, then tapped an M7 LH thread in them. Then, using a 12.9 grade LH bolt, tried again. One came out Ok with a lot of force, but the other unscrewed the top end OK, but left the heater probe in place. Tried a magnet on a stick. No joy. Could not get a grip on it with forceps, but not enough remaining to do it.
As the probe can only be held there by soot/carbon/corrosion, I thought I would give it a gentle tap to hopefully loosen it, then try the magnet again. As I withdrew the punch, the probe disappeared and dropped into the cylinder.
At this point, I had to walk away. I am determined I am NOT going to take the head off.
