Hi,
First off - terrific site. It is great to know there are people across the globe learning and building.
I've put a few hours in welding with a Hobart 175 w/ 75%/25% shielding and my results are a bit lacking. My test pieces are 3/16" (about 5mm) thick steel. My test welds are just for penetration - trying to determine optimal voltage and feed rate. So, onto my issue...
I can go an inch or so, maintaining a steady pace all the while, then at the last moment I get blowthrough. Yet, when I flip the piece, I have minimal penetration leading up to the blowthrough.
I have 1 - 4 voltage settings (with no midrange settings). My test welds have been in the 2 - 3 voltage range and i have tested wirefeed across the board with similar results.
I have tested with straight line welds as well as zigzags.
Any ideas what I may be doing wrong? I'm guessing it will all come down to nailing the perfect voltage/feed combo. I will try to post picks of these nasty welds in the following days, but are there any tips to narrowing this down in the interim?
Thanks in advance!
Thanks in advance!
