Use a D-bit? You won’t do a blind hole with a hand reamer. A reamer does not cut right the bottom of the hole. Hole must be slightly longer and will have a small bevel at the end. One reason is because the reamer should be floating in its holder and needs the small bevel/taper of the machine taper to centralise the reamer on the hole to be finished.So how do you do blind holes?
They don’t have a long start taper
I use machine reamers for blind holes nearly every day and sharpen the thingsUse a D-bit? You won’t do a blind hole with a hand reamer. A reamer does not cut right the bottom of the hole. Hole must be slightly longer and will have a small bevel at the end. One reason is because the reamer should be floating in its holder and needs the small bevel/taper of the machine taper to centralise the reamer on the hole to be finished.
Yes that's the style we use, it passes through the bronze bush and is supported I the roller bearing so it cuts straight.Ahh I assume it is one of these?
CLASSIC MINI SPECIAL TOOL, REAMER REAR RADIUS ARM. 18G588 | #1776947865
You are bidding on a CLASSIC MINI SPECIAL TOOL, REAMER REAR RADIUS ARM. 18G588 THIS SPECIAL CHURCHILL TOOL 18G 588 IS DESIGNED TO DO THE REAR RADIUS ARM BUSHES OF A CLASSIC MINI. A small chip in the dwww.worthpoint.com
Did I? Read it again. I said the taper was less on a machine reamer - but not non-existent.You said machine reamers have a taper like hand reamers. None I’ve come across have
Other than the tiny lead you can ream a blind hole especially when you’ve drilled just slightly under so the chamfer left is Minimal defending something that everyone knows has bored the **** out of me nowDid I? Read it again. I said the taper was less on a machine reamer - but not non-existent.
How do you ream right to the bottom of the hole. It must be longer than required as you cannot cut the botyom of the hole with a reamer.
Cheers, we posted one of them off this morning.And when that doesn't make the hole big enough stuff something in one flute.
Try Raynor Tool Services.
