Hello Joe,
looking at post 41, the generator output cables (Blue, red, white and black?) go to the switch. Now if you run the generator and measure voltage across 1 and 4 and 2 and 3, what voltage do you get, it should be about 120v? If so then it's at the switch, if only one of those two gives a voltage then it's in the alternator, but as you had volts there already it's not so likely.
Alec
there is two on the front panel
there labeled circuit breakers
ok thanks chaps will see if i can get hold of rocker switch first will keep you postedHello Joe,
if you can't sort out the switch and only need 240 volts, then you can connect the windings directly to the 240 volt socket (Disconnecting and by-passing the switch). You need to connect the two pairs of windings in series. If I'm right and black is 1, white is 2, blue is 3 and red is 4, then join black to white and you should have about 230 volts across blue and red. Now the switch would, I think also have an earth cable so as to earth one leg of a winding to give some protection. You need to be sure that there are no other earths anywhere which you can check with your continuity meter. Assume that there is not then connect the blue to neutral on the socket and also connect that to the generator body/frame. Connect the red to the live pole of the socket.
Alec
