Gasket material
  1. Jlg
    Jlg Member
    2,058
    Cumbria
    I need to make a gasket for a carb but I bought some gasket paper but it's no good as I need it to be 3mm thick can anyone recommend anything
  2. keithski122 Member
    823
    uk
    Cornflake box stacked?
    eLuSiVeMiTe and 123hotchef like this.
  3. grim_d
    grim_d Member
    1,480
    Scotland - Ayrshire
    Parm and brightspark like this.
  4. brightspark
    brightspark Member
    25,744
    yarm
    for what part on the carb
    Jlg likes this.
  5. Robotstar5
    Robotstar5 Casanunda Staff Member
    17,485
    Birmingham
  6. addjunkie
    addjunkie Member
    4,817
    Northumberland. Reet oot in the sticks
    Teflon sheet works well for such things. But 3x1 mm works too, if using cornflakes box, smear with grease before you assemble
    Shox Dr likes this.
  7. slim_boy_fat
    slim_boy_fat Forum Supporter
  8. Jlg
    Jlg Member
    2,058
    Cumbria
    Between the carb and engine
  9. brightspark
    brightspark Member
    25,744
    yarm
    the ones on my Norton are tufnol to stop heat transfer
  10. ronan
    ronan Member
    8,239
    dublin
    Yup, you need to give crappy amal carbs all the help they can get.
  11. Robotstar5
    17,485
    Birmingham
    and as a sparky, that wasn't hard to come by :D
    bigegg, eLuSiVeMiTe, Anguz and 2 others like this.
  12. Gwil Member
    496
    Portugal
    Tufnol apparently used to contain asbestos as a filler, so if you come across an old bit use precautions if you need to machine it.
    slim_boy_fat likes this.
  13. grim_d
    grim_d Member
    1,480
    Scotland - Ayrshire
    It's dust is nasty even even without the asbestos so care should be taken regardless.
    Gwil, Hopefuldave and slim_boy_fat like this.
  14. Ashley Burton
    Ashley Burton Member
    2,189
    Northamptonhire
    Get down your local motor factor - Victor Reinz & BGA both supply it
  15. roofman
    roofman Purveyor of fine English buckets and mops
    6,121
    North West
    Go into your local roofing stockist and on the counter there should be little EPDM samples the size of cup mats..make perfect Gaskets;)
    [​IMG]
    xmetal and Jlg like this.
Advertisements
