That is the maximum flow on my (CO2) regulator, I should have been more specific!I wouldn't recommended turning the gas fully up, as this would be as bad as no gas at all, destroying any shrouding effect. Set it at around 12Lpm & then wind it down as low as you can get away with, whilst still maintaining a nice smooth weld.
weldequip
What are your feelings on nitrogen embrittlement. It's easy to tell when you have too much oxygen (the weld bubbles and spits), but TechnicAl's mention of smaller precentages of Nitrogen causing problems had me a bit worried about reducing gas flow rate too much.
The maximum flow on your regulator could be up to 30 or 40LPM which is way too high for common DIY welding tasks.That is the maximum flow on my (CO2) regulator, I should have been more specific!
If I welded a driveshaft together I'm sure it would break
Remember the tragic death of F1 driver Ayrton Senna? The inquest concluded that the cause of the accident was a failed weld on his steering wheel shaft; it had had a shortening modification done. Wouldn't have liked to be the welder responsible for that job!
weldequip
.....It's well worth thinking about what would happen if a weld breaks. For a floorpan probably an edge would come off and wet feet would finally annoy you into fixing it. A single weld failing in most suspension systems would hopefully cause a knocking noise and weird stseering......
