julianf
- devon, uk
What i know -
Parweld xt202
Torch says "parweld progrip max" on it
Ceramic shroud measures 10.84mm ID on the end that screws on to the torch (not the thread, the non-threadded portion before the thread starts)
Ceramic shroud measures 30mm between the part thats covered by the white ring, until is starts to curve into the end (ie the parallel sides measure 30mm, not the total length)
(the end is missing, so i cant get the total length!)
OD of the shroud is about 17.8mm
ID of the exit end is about 9.6mm
There seems to be a lot of options with shrouds, and i cant work out what i need to buy to fit my torch! Ive never purchased these before, and, whilst im sure its a simple answer to some, its got me confused, and unsure what to buy to replace the damaged shroud.
Torch basically looks like this, but im sure they come in different variants. The user manual for the welder says "pro26" but lists a whole load of shrouds.
Thank you
Parweld xt202
Thank you
