These have came up before
It was worked out the proper ones that seem to fetch hundreds of pounds would only really be worth it getting through a lot of gas as the amount saved versus the cost of the gas saver for a hobbyist anyway wasn't worth it.
I know I've seen it .I have got one in the for sale section if you want one!
Although, as stated above, I think you will need to do a lot of stop-starts to make it.pay for itself!
And I certainly will be doing a lot of start stop once I get the transtig up and running . Got a box of ali off cuts as wellI have got one in the for sale section if you want one!
What’s inside? You’d think you could swap the key mechanism with a knob?I have this ancient thing, an Argonmeter II, which I think converts single stage into dual stage. Not much use without the key, though...
Can’t with no gasWell he must have a welder just weld a key on
should have economised and saved some ,,,Can’t with no gas
Get bigger bottles. The 300 bar ones too!I'm only using a 10ltr hobbyweld on the bester so it would be nice to know I'm not wasting it .That was the main reason for the OP if something for £40 even saved 5% on bottle it's worth it.
At present I can't justify the cost for big bottles the amount of welding I do .Get bigger bottles. The 300 bar ones too!
