mspence0000
Hi guys today at work I was welding on some galvanized for the first time and when I was welding together frames and I was having a little trouble, anyone have any secrets or little tips for galvanized? thanks.
Yes. Grind off the zinc where you need to weld. And wear a suitable breathing mask, galvy fumes are lethal.mspence0000 said:Hi guys today at work I was welding on some galvanized for the first time and when I was welding together frames and I was having a little trouble, anyone have any secrets or little tips for galvanized? thanks.
Hitachimad said:Yes. Grind off the zinc where you need to weld. And wear a suitable breathing mask, galvy fumes are lethal.
Nial said:steel? There isn't any particular warning on the tin about welding with it
and it says it's 99% zinc.
jolly_roger187 said:Yes.... The zink will evaporate into harmfull vapours, be sure to weld in an area that is well ventilated.Nial said:steel? There isn't any particular warning on the tin about welding with it
Hitachimad said:You are likely to sufer from 'metal fume fever' you get a pain in the kidneys and chest, aching joints and other flu like symptoms. They might not appear for a few hours after, and can last anything upto a few days.
