Gareth0123
You'll need 16 pigs to do the job in one sitting!
- Norwich, Norfolk, UK
I'm fumin' but it's atually my fault
In mid November I took my Draper vertical bandsaw to a local repair man who has both a very good reputation and has done PAT testing and repair jobs for me in the past, including replacing the power cables on various angle grinders, powerfiles and Jigsaws, and has replaced motor brushes in various other power tools including a sliding mitre saw for me.
It seemed sensible to me to let him have my rather old made in 1996 Draper Vertical bandsaw in for repair when it began making loud noises. I bought this Bandsaw second hand for £30 back in 2010, and even though it has only done a total of 20-25ish hours of work in all those years it owes me absolutely nothing and it even still had the 10mm wide X 1mm thick X 6TPI blade I bought it with..... had being the operative word here.
I took it in for repair, told him to get around to it when he could as I was in no rush whatsoever and he's had it for about seven maybe eight weeks now.
I rang him up yesterday to see if it was ready as I now need it and the reply was yes. The Bill was £30 all in for new motor brushes, a thorough clean and a PAT test, all of which I thought was very reasonable until I picked the saw up this morning.
It is immaculately clean, the motor runs smoothly and quietly and there is a nice bright green PAT test sticker on it..... lovely jubbly I thought until I noticed the blade was missing. So I enquired about the missing blade as I knew for a fact it had one on when I took it in to him.
The answer I got was: "My insurance company won't allow me to return a repaired power tool with the existing blade in it or disc in it"
I replied; "OK, can I have the blade, I'll refit it when I get back home."
"Sorry, No. I haven't got it, I have to dispose of them when I take them off."
"What about the sliding cross-cut Mitre saw you repaired for me last Autumn then?"
"Er,, that didn't have a blade on it when it came in."
(That's when I remembered that my table saw, mitre saw and circular saw all have the same size blades and I swap them about to suit the job at hand.)
"So why didn't you tell me about this new policy of disposing of fitted blades and discs then?"
"Er, didn't you read the big sign hanging up behind me over the counter or the clearly visible note on the job acceptance receipt that you signed?"
"Doh!"
Anyway my lesson is learnt ............... and on the plus side I have two new blades on the way to me from Amazon. Both of the new replacements are 6.35mm wide X 1mm thick, one is 10tpi and the second is 14tpi, both of which will hopefully make cleaner, smoother and tighter more detailed radius cuts.
"Doh!"
