My generator has this sensor / fuel pickup combo.
Problem is it only allows about 20-22L of fuel to be used out of an aprox 40+L tank.
The genny is sold as having a 20L tank but actrually has a bigger one.
Now I think this is to stop warranty claims re dirty fuel getting into the system.
However 20 ish liters does not quite do a full days use so we need to top up each day.
I was hoping to just extend the float by glueing a second float to the bottom & possibly extending the pick up a bit.
When the genny shuts down due to low fuel there is still a good 2+" left. Its only about 4 to 5" deep when full.
The sensor is obviously a variable resistor not just an on off switch as the genny can also shut down if fuel useage is excessive ie a leak not just on low level.
You can also set the minimum level (its on as low as it can go).
Any suggestions of making this work easily?
You can see it form more angles here
							 spareandsquare.co.uk
				Electrical fuel level sensor for DHY9KSEm & DHY11KSE - Canopy Parts(3/4)-09
Electrical fuel level sensor for DHY9KSEm & DHY11KSE - Canopy Parts(3/4)-09Genuine OEM Replacement PartManufacturer Part Number: 1027345Parts Diagram Reference: DHY9KSEm & DHY11KSE - Canopy Parts(3/4)-09-=DHY9KSEm HY380 CompatibilityMakesHyundaiModelsDHY9KSEm HY380
