Is that all i will need then? (gas cylinder obviously) does the small hose from the back of my welder just fit into that? as you can tell i havnt exactly read the instructions that came with it, and dont have them to hand
Yes, the small white pipe just pushes into the fitting on the end of the rubber hose.
All you then need is a cylinder of gas, some normal mig wire and you're away.
Edit: You also need to swap the polarity of the machine.
