We've had this. Still no building where a whacking great concrete sectional garage sat. Roughly 5m x 15m.Don't trust or have any faith in planning!
We want to knock down out garage plus attached outbuildings, then knock down a separate workshop and rebuild bigger
Told us we could do the garage under permitted development... so we knocked it down... now they changed their mind and said we can't rebuild the garage because its too big... even tho it's the sane size of the stuff it's replacing.
I laid a base for a steel framed building a few years ago, that was basically a raft with the stanchion bases all cast in as one. The reobars for the pits dug for the stanchions were tied in with the raft reinforcing mesh. That was to building regs.
It’s worth spending time on the base and getting it laid out so that the side sheets of the building are tight against the side of the slab and that they sail past it by at least 100mm.
Bob
View attachment 524086View attachment 524087View attachment 524088
So, that’s a simple reinforced concrete slab? No pads under the columns and no thickening around the perimeter?My 8x12m steel framed garage / workshop is bolted down to a 6" concrete base.View attachment 524090
Yep.So, that’s a simple reinforced concrete slab? No pads under the columns and no thickening around the perimeter?
That frame is quite light in comparison to many similar buildings in size.My 8x12m steel framed garage / workshop is bolted down to a 6" concrete base.View attachment 524090
If this happened to me I would employ a planning consultant. Find an independent one and they are not too expensive, last one I spoke to wanted around £1k for a house knock down and rebuild.We were.... but its taken locsl planning department a bit over 20 weeks to give us a reply... saying no too garage its too big, and no to workshop because it'll be too big and they want a tree assessment to mske sure we don't harm any trees...
But like I said garage is sane suze as what we took down
And where workshop is the people who owned this before us had planning to build a road, fancy house and detached garage... and then the sane again a bit further along.
Its been a total waste of time, real kick in the nuts.
People who lived here before us hired sone flash company to run their appeal for them to get the permission for the houses... we'll track them down and see how much they'll charge.
Own design.
Two separate buildings each under 30 square metres. Both garages, although one will be used primarily for restoring a couple of cars, the other for storing the cars when they aren’t being worked on. Virtually no gap between them. Constrained between a property boundary on the rear and the long side and an existing building on the shortest side.
Clay. Happy to be corrected but as I understand it, if they are under 30 square metres and built of substantially fire proof materials, no building regs are required.
The maximum height is 2.5m dropping to 2.1m at the eaves on the boundary.
That’s an interesting approach. I have seen that done on larger buildings. Food for thought.
The soil is clay but not a mining area. How big was your building?
